DIY - Replacing the Driver's Side Seat Tracks on the C5
So I'm rolling along, not moving too fast when plop! My seat drops about 2" in the rear. I think to myself. "That's not good...", and when I go to exit the car, my seat doesn't move back to let me out. At that moment, I realize that I have lost a seat track. Upon further investigation, I find a piece of metal that has totally separated from the seat track somewhere. It turns out that what it had separated from was the track bracket itself. Here's a shot of the broken area. This picture may not make complete sense to you unless you've dealt with the seat completely stripped down but you will have clarity by the end of this DIY.
[Bild: seat_track1.jpg]
Close up.
[Bild: seat_track2.jpg]
At first, one would think that I needed to lay off some bowls of Captain Crunch but apparently, this is a common failure. The pounding that the tracks take with people falling into the car (c'mon guys, you know who you are), is enough to wear these seat tracks out over time. It's not a poor design, it's your poor entry technique.
When faced with this failure, you have two choices. One is to replace the tracks with new ones, which is what I did. I got a great deal from Grabiak Chevrolet in PA where I do a detailing clinic but you will have to call around to see what you can get them for. Think upwards of $600 for new.
The other choice is to send your tracks off to be repaired. That can be done for around $200 at Dino's Corvette Salvage, or you can check for a used set at some place like Corvette Recycling or the Parts Taxi. I will say that they have changed the design slightly with the new tracks and they are much smoother and a lot quieter. They still plug and play so that won't be an issue.
In order to do this repair, you need to remove the seat from the car and remove the bottom cushion from the seat. Two things that I highly recommend that you go buy are some hog ring pliers and some hog rings. You'll thank me later. This is not a tool that you will use a lot unless you work in the automotive upholstery field but they are worth their weight in gold when dealing with the leather on your seats.
[Bild: seat_remove_11.jpg]
So let's get that seat out of the car!
There's no need for me to reinvent the wheel so I am going to point you to the [URL="https://www.vetteessentials.com/instructions/full_seat_covers/full_seat_cover_change.html"]Vette Essentials[/URL] website for the instructions on how to remove the seat from the car. However, I am going to interject some things that I found to be helpful with more detail included. In their directions, they start with the passenger's seat which only has 1 power connector. The driver's side has two connectors and a connection for the seat belt but that's the only difference.
When you get to step 4a, it talks about removing the electrical connections that are plugged into the seat. They really don't have a good picture of how this plug is connected to the tracks so I will provide a couple of pictures here that should help. Explaining it in words is even more confusing.
[Bild: seat_remove_0.jpg]
Here a close up of the connectors that show the seat clips in and out:
[Bild: seat_remove_2.jpg]
[Bild: seat_remove_3.jpg]
Everything should go smooth until you get to step 10a.
Explaining how to remove that handle is difficult. Again, pictures are worth a thousand words. The easiest way that I have found to remove the handle is to stick a flat-head screwdriver down into the handle and to depress the spring. The handle will slip right off the shaft when you depress the spring. The spring is very similar to the spring that holds the roll up window knobs on cars from the 70's (I've never taken a window knob off anything newer so they may still use the same spring). Here's a picture of the handle and the spring which must be depressed:
[Bild: seat_remove_4.jpg]
[Bild: seat_remove_5.jpg]
Now the next thing you have to figure out is exactly where and what angle to stick the screwdriver down into the handle. Never fear, "pic man" is here!
Here's a picture of the handle on the seat as you will see it, and then with everything removed for clarity.
[Bild: seat_remove_6.jpg]
[Bild: seat_remove_7.jpg]
Coming down like so with a flat head screwdriver will allow you to depress the spring and slip the handle off the shaft. You'll need to slip the screwdriver between the handle and cover first, and then give it a slight turn so that you can hit the top of the spring.
[Bild: seat_remove_8.jpg]
Now there is a chance that your spring may be installed the way GM initially designed it to be. If you look at the bottom of the handle, you will see a slit where you can insert a flat head screwdriver and depress the spring if yours is opposite of mine. Somebody at the plant screwed up when they put that spring on the handle and apparently, that person built a lot of Corvettes because all the springs that I have seen are upside down like mine. :crazy:
From step 5 - Step 9b, it talks about removing the center back support of the sport style seat. I removed mine because I was doing something else with my seats. You may or may not have to remove yours depending on the design of your leather seats, however, I found it to be much easier if you do. There's not much to it so you should do so anyway. You do not have to remove the leather from the foam, just remove the center section.
Now when you get to step 11c, you have to be careful so that you don't break any of the post on the back of the cover. The main one that you need to watch out for is the one at the front of the seat. Look at the picture below:
[Bild: seat_remove_9.jpg]
Here's a picture of the spring loaded post.
[Bild: seat_remove_10.jpg]
Follow the Vette Essentials instructions down to step 15b and you will be able to lift the bottom cushion off the seat frame and start removing the tracks.
[SIZE="4"]Removing the Seat Tracks[/SIZE]
There are for bolts that actually hold the seat tracks to the seat. There are also some connectors that need to be unplugged in order to separate the two. Here is a shot of the new tracks I bought.
[Bild: seat_track3.jpg]
First, remove the old tracks from your seat by removing the 4 bolts that hold the two together (notice that I have removed all of the leather off my seats for another DIY project that I was doing).
[Bild: seat_track6.jpg]
Next, you need to disconnect the electrical connectors that control the seats. Start by separating the seat from the tracks in a clam shell fashion.
[Bild: seat_track7.jpg]
Next, disconnect the following connector.
[Bild: seat_track8.jpg]
[Bild: seat_track9.jpg]
Then disconnect the plug from this motor.
[Bild: seat_track10.jpg]
[Bild: seat_track11.jpg]
Disconnect this bag and harness by cutting the tie wraps.
[Bild: seat_track12.jpg]
Disconnect the harness from the two motors.
[Bild: seat_track13.jpg]
Important! Those motors control specific direction of movement so you don't want to plug the harness back up incorrectly. Only unplug one connector and then mark it and the associated motor. This will keep you from making an obviously annoying mistake.
[Bild: seat_track14.jpg]
[Bild: seat_track15.jpg]
At this point, you should be able to totally separate the seat tracks from the seat. This is also a opportune time to re-wrap all of your wiring with electrical tape. One thing to note about this picture is that I am in the process of changing out my seat belt receptacle so you may notice a extra connector that is not plugged up. That goes to the seat belt receptacle.
[Bild: seat_track16.jpg]
Now comes the tricky part. I have circled the 4 shafts on the new tracks that the seat is going to mount to.
[Bild: seat_track4.jpg]
Do you see how the rear mounting shafts are flipped upside down? That's the way I received my tracks. At first, I thought I had received the wrong part because I didn't know how to rotate the pressed fitted shafts but after inspecting my old & new seat tracks side by side, I realized that the part which had the shafts press fitted, actually rotated.
[Bild: seat_track5.jpg]
Here's a shot of my old tracks with everything orientated to accept the seat.
[Bild: seat_track18.jpg]
In order to rotate the part of the tracks that can't be rotated manually (without busting the new motors), I set the entire seat inside the car, plugged up the power and started playing with the controls. After a little trial and error (and looking at my old tracks), I figured out how to adjust the press fitted shafts so that I could properly attach the seat. Once I had figured that out, the rest the repair was simply putting it all back together.
[Bild: seat_track17.jpg]
That's pretty much it. You basically reverse the process to reassemble everything. :thumbsup:
Some things to consider when doing this repair. I reinforced my seats the last time I replaced the leather. You can see some of the things that I did in my [URL="https://www.digitalcorvettes.com/forums/showthread.php?t=104955"]C5 sport seat leather replacement thread[/URL]. One of the most beneficial, and one that you can easily do at this point is to reinforce the bottom cushion so that the seat and springs don't eat up your foam. I used some heavy traffic carpet across the springs to keep from damaging my foam and allowing the bottom cushion to eventually sink too low. This big time saved my bottom foam.
[Bild: seat_track19.jpg]
After almost 4 years of use, my foam shows no sign of wear.
[Bild: seat_track20.jpg]
Unlike the original foam that showed plenty of wear.
[Bild: seat_foam2.jpg]
So that's it folks! You now know what it will take to not only replace your seat tracks, you also have a few different options. Holler if you have any questions! :buhbye:
The Junkman :cheers:
"The Germans call us devil dogs (Teufelshunde), our title is Marines."
Yeeah! Pokal Hello again Junkman. What a detailed DIY manual Dafür Respekt I like your Tipps a lot, because every C5 driver can have the described problems any time. Keep on writing about your detailed DIY´s.
Cheers from Germany
Dieter Patriot
[Bild: osc_logo_klein.gif] [Bild: DieterBanner.jpg]
OK! take it easy, but take it OK!
Thank you Dieter. Good to see that you're still here. Hallo-gruen
  Driver Seat Control Modul 09360841 er12345 8 5.564 28.02.2024, 00:00
Letzter Beitrag: Pfälzer73
  Einbau einer Sitzheizung für C5-Driver Manni 28 31.165 03.11.2018, 10:31
Letzter Beitrag: heiner88
  Folieren DIY renz54 88 61.974 22.05.2017, 13:14
Letzter Beitrag: C4_driver
  Side Marker 8erChamp 1 5.037 21.05.2011, 18:19
Letzter Beitrag: Thomas V
  DIY - Ersetzen der Fahrerseite Schließzylinder Junkman2008 11 11.396 02.04.2010, 15:40
Letzter Beitrag: Darkgreenneon
