Anyone building a 383 for a C3?
My block didn't clear up on three cyl, so I have 8 forged Ross racing pistons and Speed Pro plasma/moly rings for sale!
Pistons can take 250 hk NOS
Absolute highest quality!
Bore (in): 4.030 in.
Rod 6"
Stroke 3.75
Piston Material: Forged aluminum
Piston Style: Flat top
Compression Distance (in): 1.133 in.
Piston Head Volume (cc): +4.00cc
Valve Reliefs: Two
Wrist Pin Style: Floating
Pin Diameter (in): 0.927 in.
Top Ring Thickness: 1/16 in.
Second Ring Thickness: 1/16 in.
Oil Ring Thickness: 1/8 in.
Weight is 486 grams.
Comp: 10,7/64cc 9,5/76cc
5000 SEK or give me an offer!
[Bild: 9209-327192.jpg]
Instaed of selling the pistons you have the possibility to mill the block.
No, I must go up to +40 or +60 as the cylinders didn't clear up!
Hi
You could sleeve the 3 cylinders. Might be sheaper than selling your rotating assembly.
Günther
Yes I could put in sleeves!
Didn't think of that.
I already bought 8 new Probe SRS Pistons at +60, so I will go for them now.
Smile Supercharger für meinen 383 stroker? peterbx1 11 12.116 24.08.2025, 14:30
Letzter Beitrag: olaf 1965
  383 Stroker und Sidepipes Eintragung TÜV paden1 54 14.845 25.02.2024, 17:50
Letzter Beitrag: Ulivette
  Corvette 383 Stroker...mein Prüfstandslauf! Maxxx74 24 8.752 14.06.2023, 19:54
Letzter Beitrag: daabm
  383 Stroker Thermostat paden1 12 5.207 08.06.2023, 15:23
Letzter Beitrag: corvette
Sad Teil - Resto meiner 75er Vette mit Motorumbau auf 383 Stroker! jensl76 428 159.070 09.04.2021, 08:09
Letzter Beitrag: jensl76
