Der Kriechöl Thread :-)
Hier das original Rezept "Ed's Red'Bore Cleaner"
CONTENTS: Ed's Red Bore Cleaner
1 part Dexron II, IIe or III ATF, GM Spec. D-20265 or later.
1 part Kerosene - deodorized, K1
1 part Aliphatic Mineral Spirits, Fed. Spec. TT-T-2981F, CAS
#64741-49-9, or may substitute "Stoddard Solvent", CAS #8052-41-3, or
equivalent, (aka "Varsol")
1 part Acetone, CAS #67-64-1.
(Optional up to 1 lb. of Lanolin, Anhydrous, USP per gallon, OK to
substitute Lanolin, Modified, Topical Lubricant, from the drug store)
MIXING INSTRUCTIONS FOR "ER" BORE CLEANER:
Mix outdoors, in good ventilation. Use a clean 1 gallon metal,
chemical-resistant, heavy gage PET or PVC plastic container. NFPA
approved plastic gasoline storage containers are also OK. Do NOT use
HDPE, which is permeable, because the acetone will eventually evaporate.
The acetone in ER will also attack HDPE, causing the container to
collapse, making a heck of a mess!
Add the ATF first. Use the empty container to measure the other
components, so that it is thoroughly rinsed. If you incorporate the
lanolin into the mixture, melt this carefully in a double boiler, taking
precautions against fire. Pour the melted lanolin it into a larger
container, rinsing the lanolin container with the bore cleaner mix, and
stirring until it is all dissolved.
I recommend diverting a small quantity, up to 4 ozs. per quart of the
50-50 ATF/kerosene mix for optional use as an "ER-compatible" gun oil.
This can be done without impairing the effectiveness of the remaining
mix.
Grüssle Daniel
[Bild: drhouse.jpg]
Zitat:for optional use as an "ER-compatible" gun oil.
Ist doch ne super Idee, brauche jeder.
Danke für die Tips. Die Aceton-ATF Mischung, wie lange bleibt die gebrauchsfähig?
Gruss RainerR
RaRo
So lange, bis das Aceton weg ist... Feixen
Und das geht bei ungeeignetem Behältnis vermutlich recht schnell, ggfs. auch durch die Wand, da Aceton hoch flüchtig ist. Ideal daher wohl 'ne Blechdose oder Glasflasche, jeweils mit luftdichtem Verschluss.
I used to be indecisive. Now I'm not so sure.
Nothing is foolproof to a sufficiently talented fool.
Schütteln vorher nicht vergessen da sich die das zeug recht schnell entmischen sollte....
Grüssle Daniel
[Bild: drhouse.jpg]
Also mal ganz ehrlich, Caramba, WD40, und wie die Kriechöle alle heißen, sind allesamt Sch...!
Wenn eine Schraube richtig festgerostet ist, helfen die handelsüblichen Rostlöser null.
Am eigenen Leib, äh Auto schon zigmal erleben müssen, bis zu einer Woche vorher die Schrauben mit Kriechöl eingesprüht, jeden Tag, immer wieder, und was war das Ergebnis? Die Schrauben gingen entweder gar nicht, oder fast nicht auf und das Gewinde 1mm nach dem Kopf war knochentrocken! Soviel zum Kriechen... Motzen
Das Einzige, was den Rost aufsprengen kann ist Hitze oder Kälte. Bei den Kältespays ist die Wirkung ebenso fast Null, wenn es sich um eine Schraube handelt, die in einem massiven Stück sitzt, dann wird nur der Kopf kalt. Bei Muttern sieht das Ganze dann schon besser aus.
Sry für die harten Worte, aber so siehts numal aus.
Gruß Robert
@Robert: Vielleicht dann doch mal ATF/Aceton Cocktail? Bin auf FtJ Erfahrung gespannt.
Noplan
naja, es gibt immer Schrauben die so festgerostet sind und sich Ihren Platz hart erarbeitet haben. da hilft dann wirklich nur mehr gutes Zureden mit dem Autogenzeugs!
aber für alles dazwischen hilft es schon
Schraubverbindung liegt seit gestern Abend in der Chemikalie. Über den unglaublichen Gestank hätte man mich vorher informieren sollen. Richter
Die im Büro finden die ganzen lila Sterne nicht ganz so dolle. [Bild: 90.gif]
Später mehr.
Versuch mal Dichlormethan. Da fangen die lila Sterne an zu rappen OK!
mfg René
  Neues aus der Abt. Lack & Leder , Heute: Quixx sei Dank! – der Vogelkitt DON 1 4.219 11.10.2013, 15:09
Letzter Beitrag: TommyW.
  Here's a cool thread, Check out the history of the last couple generations of Corvette with images. Harleytheo 0 1.928 22.05.2012, 16:23
Letzter Beitrag: Harleytheo
  Wieviel Grade hat der Konus vom Tierod-end (Gelenkkopf von der Spurstange) für C3? Günther-C3 9 13.400 03.02.2012, 20:39
Letzter Beitrag: mad_mike
  Thread über Lebensdauer von Öl String 8 3.670 28.02.2008, 01:19
Letzter Beitrag: VetteRuby
  Der Alptraum ohne Funktion nachts auf der Autobahn, Vernetzung CAN Bus VetteRuby 44 15.198 01.01.2008, 16:38
Letzter Beitrag: AK
