What oil to run?
Hello,
sorry, I write in English.
What oil are you guys running? My American manual says 5w30 for everyday and 15w50 for track days. I do drive rather aggressively on the autobahn, and I go to nurburgring once or twice a month. In the summer, when it was hot, I saw oil temp go up very high (almost to red line). I'm thinking of switching to 15w50 for everyday driving.
c7 z51
Hallo Ilya,
first of all you should get used to put your name under everything you write.
and yes the red C 7 is mine.
I brougt it here when i moved from New Mexico to Germany.
I made all the changes to EU spec on my own.
I've been using Mobile 1 15W50 for almost 10,000 Km on a daily base
including the Autobahn and never had a problem with Oil temp.
Sins you can buy it on base, (i guess) for a reasonable price, i can recommand it for day by day use.
I have a summer season licence plate from April to October so next saturday ist end of season.
we can meet but the Corvette is almost ready for storage.
you can pm me.
Heiner
Patriot
[Bild: 21086623ga.jpg]
thank you for the info.
American warranty covers first 5 oil changes, and my dealer here told me that he will honor that. However when I spoke to him yesterday, he said that only 5w30 is covered under warranty :( I may have to contact regional rep or something. I wonder what the german owners manual says.
I have all season plates, so i'll drive it until the first snow. I'd love to meet with you and get more info on converting.
v/r
ilya
c7 z51
Ilya, that´s correct, don´t use 15W50 when you want to stay under warrenty and avoid valve lifter noise.
Best regards
Edgar
Alternatively you can
use 5-50 mobill 1.
@ Edgar
du schreibst zu viel, und weißt offensichtlich garnicht mehr was. Augenrollen
Im letzten C7 Öl-Thread Feb.2015 hast du noch genau das Gegnteil geschrieben.
Dein Text:
Die erhöhten Anforderungen des Herstellers für den Rennstreckenbetrieb auch im Alltag zu erfüllen
dürfte ja überobligationsmäßig sein, also die Garantie nicht tangieren.
Edgar
Die Garantie ist nicht weg das hat sich auch in dem letzten C7 Öl- Thread geklärt:
Cardever schrieb:
So alles geklärt!
Mobil 15W 50 darf auch gefahren werden im normalen Betrieb!
Garantie erlischt nicht!
Er hatte wohl den Händler angefragt.
Die US Garantie geht auch nicht verloren das hatte ich schon in meiner Zeit in den USA geklärt.
Und wo nimmst du deine Infos über "valve lifter noise" her, du fährst doch gar kein 15-W50 ?
Nach knapp 10000 Km mit 15W50 hatte ich nie auch nur ein einziges Mal irgend ein Geräuch, im Gegenteil,
der Motor scheint sogar ruhiger zu laufen, und heißer als 126 Grad C wurde mein ÖL noch nie, auch nicht bei längeren Fahrten über 280 Km/h.
@ ilya
dont worry, warranty will still cover, but you should call your regional rep to be save.
And the last 10,000 Km with 15W50 there was never any valve lifter noise . Feixen
Heiner
Patriot
Hi folks,
what about reading the owners manual??
>>Engine oils that have been
approved by GM as meeting the
dexos1 specification are marked
with the dexos1 approved logo. See
http://www.gmdexos.com.<<
Dry sump or "normal" engine?
>>GM recommends Mobil 1®
engine oils that show the dexos1 approved
logo for its dry sump equipped
engines<<
Viscosity Grade??
>>Use SAE 5W-30 viscosity grade
engine oil.<<
Cold temperature or track events??
>>Cold Temperature Operation: In an
area of extreme cold, where the
temperature falls below 29°C (20°F),
an SAE 0W-30 oil may be used.
An oil of this viscosity grade will
provide easier cold starting for the
engine at extremely low temperatures.
When selecting an oil of the
appropriate viscosity grade,
always select an oil of the correct
specification. See “Specification”
earlier in this section for more
information.
For track events or competitive
driving, use Mobil 1® 15W-50 engine
oil. An instrument cluster warning
light will be illuminated at high oil
temperatures. See Driver
Information Center (DIC) on
page 5-26<<
If you unfortunately should not find your owners manual, here it is: ;-))
https://www.chevrolet.com/content/dam/Ch...manual.pdf
Best regards, have fun and don't forget to check your engine oil driver
Peter
Hallo-gruen
Thanks Peter,
that was really helpfull. sich vor Lachen auf dem Boden wälzen sich vor Lachen auf dem Boden wälzen
when i drive its always "competitive driving" Hallo-gruen
by the way "GM recommends"
Translation: vorschlagen, empfehlen.
that means Klo
the only thing you have to do, is using 05W30 or 15W50 (read the manual)
what brand is you choise.
GM recommands 5w-30 because the Corvette needs 2 % less fuel. Feixen
Heiner
Patriot
sorry hit the wrong button Feixen
Patriot
Heiner, das nehme ich aus den Erfahrungen mit Fällen in der letzten Zeit. Deshalb, um auf der absolut sicheren Seite zu sein, würde ich mich während der Garantie strikt an die GM Vorgabe halten, nicht mehr und nicht weniger. Das bezog sich nicht auf meine C7 und soll auch nicht heißen, daß ich meine oder beurteilen könnte, ob ein 15W50 ungeeignet wäre.
Edgar
  Oil kühlung toni1967 0 2.282 04.08.2019, 12:32
Letzter Beitrag: toni1967
  Run-Flat funzt aber was im Winter MRgK 4 6.778 30.09.2018, 09:42
