22.12.2014, 14:52
In diesem amerikanischen Forum heißt es, dass die Z06 mit beiden Ausführungen der Winglets geliefert wird. Die großen können für den Track angeschraubt werden, die kleinen sind für den Alltag gedacht.
https://www.corvetteforum.com/forums/c7-...ncern.html
Hier kann man die kleine Ausführung erkennen:
https://www.roadandtrack.com/new-cars/ne...1/?slide=2
Infos zum Z06 Paket gibt es auch hier:
https://www.chevycorvette.com/2015-corvette-z06
The Z07 package pushes the Z06's performance to the limit.
A track-focused Z07 Performance Package adds unique components for true aerodynamic downforce, Michelin Pilot Super Sport Cup tires for enhanced grip, and Brembo carbon ceramic-matrix brake rotors that improve braking performance and contribute to greater handling through reduced unsprung weight. Although development testing is ongoing, the Z07 package has already recorded some of the fastest lap times ever for a Corvette, surpassing even the ZR1.
Features of the Z07 Performance Package include:
•The Z07 package adds larger, 15.5 x 1.4-inch (394 x 36 mm) front and 15.3 x 1.3-inch (388 x 33 mm) carbon ceramic-matrix brake rotors for consistent performance lap after lap, and collectively save 23 pounds over the standard Z06 rotors.
•The Z07 package includes Michelin Sport Cup 2 tires (upgraded from the standard Pilot Super Sport tires on the Z06)
•The available Z07 package add larger winglets to the front splitter, along with an adjustable, see-through center section on the rear spoiler for track use. With this package, the Corvette Z06 delivers the most aerodynamic downforce of any production car that GM has tested.
The cost of the Z07 package is $7,995.
Zitat:GM is calling them "splitter winglets" and on the Z07 they come in the trunk of the car. You don't have to put them on if you don't want to and can use the smaller ones instead.
Zitat:They are removable.
The package comes with two sets of winglets, one about 2-3 inches tall and less wide and one about 11 inches tall. They are held on with two bolts. The idea is to use the tall ones on the track and the small ones on the street.
