Rückruf in USA "Roofpanel"may blow off"
zur Info, falls noch nicht bekannt.
Habe ich heute gerade in Autonews/US gelesen.
Grüße/Heinrich
Link:
https://www.autonews.com/apps/pbcs.dll/a...99998/1261
"General Motors Co. is recalling Chevrolet Corvettes from the 2005 through 2007 model years because the roof panel may blow off.
The recall covers Corvette coupes with the removable roof panel. There's a problem with the adhesive that bonds the plastic roof panel to its frame. If the bond breaks, the roof panel could go flying off while driving.
There are clues to the problem, such as a snapping noise from the roof when driving over bumps, water leaking from the headliner, or the roof panel moving when the door is closed.
Nearly 22,100 cars are involved in the recall. Those with a bad panel -- GM has previously run a customer satisfaction campaign for this problem -- will get a new panel. GM says it will start the recall in January.
Read more: https://www.autonews.com/apps/pbcs.dll/a...z0bkA9RDMX
NOCH ein Rückruf wegen der Dächer oder ist die Meldung alt?
https://www.corvetteactioncenter.com/for...roofs.html
Geb´s mal so weiter aus dem Newsletter.
Hallo-gruen , ...............
oder auch schon hier King
"You'd have to be bonkers to buy the Corvette. And that is why you should."
Jeremy Clarkson | TopGear | Corvette ZR1 vs Audi R8 V10
  Demnächst Rückruf C6 schwampe 101 55.667 01.12.2022, 20:39
Letzter Beitrag: Z06FAN
  Versand Front USA Deutschland FelixAC 10 29.488 05.05.2019, 23:24
Letzter Beitrag: FelixAC
  Unterschied Grand Sport USA/ Europa PLATINUM 24 20.628 28.10.2018, 14:55
Letzter Beitrag: KSamanek
  Transportkosten aus USA Andreas Z06 2 3.848 25.01.2018, 17:55
Letzter Beitrag: Andreas Z06
  C6 Rückrufe in USA Eisbär Lars 0 3.318 15.05.2014, 22:38
Letzter Beitrag: Eisbär Lars
