FAST "LSXR" 102mm for LS3/L92 Heads
Für einige sicher interressant, im US Forum gefunden:
https://forums.corvetteforum.com/c5-tech...heads.html
https://www.fuelairspark.com/WhatsNew/
[Bild: 146102-T.jpg]
LSXR™ 102mm Intake Manifold
The engineers at FAST™ teamed up with the airflow specialists at RHS™ to develop a three-piece, polymer intake manifold for rectangular port GM LS3/L92 engines. Testing on a stock LS3 engine with a Big Mouth 102mm Throttle Body™ produced gains of 14+ horsepower and 11ft/lbs of torque at the flywheel over the stock intake.
Following the path charted by the original FAST™ LSX™ Gen III Manifold, the new LSXR 102mm Intake Manifold features a three-piece modular design that allows easy disassembly and porting. Extensive testing led to a runner design that is longer and less restrictive, yielding both torque and power gains over the stock intake. New to this design is the ability to remove individual runners from the manifold for modification.
The LSXR™ is constructed from a proprietary advanced polymer material which offers a host of benefits over aluminum aftermarket intakes, including lighter weight, strength and improved heat dissipating characteristics. While the LSXR™ features a 102mm air inlet that is perfectly suited to the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock or aftermarket 90mm or 92mm throttle bodies. Other features include integrated nitrous bungs and perfect bolt-on fitment that allows use of factory accessories without modification or clearance concerns.
For more information about the FAST™ LSXR™ 102mm Intake Manifold or any other FAST™ product, call us at 1-877-334-8355, or visit us online at http://www.fuelairspark.com.
  Kunststoff Abdeckung LS3 Motor passt nicht ?? C5Karl 6 9.913 08.03.2020, 21:26
Letzter Beitrag: C5Karl
  Test Corvette C7 Z06 (Fast LAP) winni123 1 6.586 04.09.2018, 14:38
Letzter Beitrag: TIKT-Performance
  C5 Z06 vs. C6 LS3 Z51 - Vergleich u. Wertstabilität Noplan 0 4.157 06.02.2016, 19:03
Letzter Beitrag: Noplan
  EFI Hilborn / Fast XFI Blackvette68 0 3.648 03.05.2013, 08:39
Letzter Beitrag: Blackvette68
  Vergleich von C6 LS3, Z06 und ZR1: Beschleunigung aus dem Stand – ACHTUNG MATHEMATISCHE FORMELN !!! UncleRobb 111 74.905 07.07.2012, 13:10
Letzter Beitrag: UncleRobb
