Hinterachse
Ach, ein interessanter Link fällt mir da gerade noch ein: Keisler in den USA bietet die Tremec TKO-Schaltgetriebe in 5- und 6-Gang als Drop-in Variante an.
Kosten je nach Ausführung ca. 3000 - 5000 $
http://www.keislerauto.com
Sieht so aus:
[Bild: tko-600_bell-sm.jpg]
copyright by Keisler automotive
Gruss,
Zitat:Original von Goofy
Zitat:das kann ja jeder.....)
.....der lesen kann. huahua
Im Black Book gibts auch Bilder...... Engel
Gruss,
Das folgende zum Dana 44 habe ich mal von "Cheynut" kopiert:
I have never seen any published torque ratings for either the Dana 36 or Dana 44. What I do know is that all automatic tranny Corvettes came with the Dana 36 in all years and gear ratios varied from 2.59 to 3.31. The Dana 44 came with all manual tranny cars except for the '84's and they had factory gear ratios from 3.07 to 3.54. The ratios depended on the year of manufacture and the option (ZR-1, etc.). The Dana 44 can be fitted with 4.10 gears too.
The Dana 36 has a 7.875" ring gear, and the Dana 44 has 8.5". Both have aluminum cases and covers and all C4 diffs are POSI. I am not convinced that ring gear size alone is the ultimate indicator of differential strength. However, the iron 9" Ford is most likely quite a bit stronger than the Dana 44. But how strong does it need to be for a street car with street tires?
The Corvette Dana 44 is sometimes referred to as the "Dana Super 44". It has a special gearset that does not fit in other Dana 44 units (like the jeeps and trucks), so don't go by the other differential's torue ratings. It's also the same differential used in the Dodge Vipers which now put out 505 HP. The Calloway Twin Turbo Corvettes used the Dana 44 and put out 560 ft-lb of torque. I'm not aware of any problems with it.
So, the bottom line is that I believe if you're not running huge slicks, both the Dana 36 and the Dana 44 can take a fair amount of abuse. Obviously the Dana 44 is stronger, but I don't know how to quantify it.
So, jetzt wissen wir immer noch nicht das verträgliche Drehmoment der Dana 44 Hinterachse, haben aber gelernt, dass es eine Menge packen kann...
@454 BIG: Paßt das Tremec 5 bzw. 6 Gang als Schaltgetriebe als Drop in für ein TH350 bzw. 400?
Beste Grüße
Zitat:@454 BIG: Paßt das Tremec 5 bzw. 6 Gang als Schaltgetriebe als Drop in für ein TH350 bzw. 400?
Für die C 3 mit Sicherheit ja - Modifikationen sind an der Quertraverse erforderlich - für die Getriebehalslagerung.
Dann natürlich noch das Kupplungsgestänge, der Halter am Rahmen und am Motor und die Pedalerie im Innenraum - noch was? Ja, wahrscheinlich neue Kardanwelle....
Der Schalthebel kann auch versetzt auf dem Getriebe montiert werden - ich hab die technischen Unterlagen von Keisler zuhause.
Ich bin mir nicht sicher, ob Keisler auch für die C 2 spezifiziert hat........... Jedenfalls stand Mikey schon sabbernd davor...... Narr Engel
Gruss,
T56 sechs-Gang mit Adapterplatte für C2 und C3... Ca. 2.800 Dollar.
Zum Weitersabbern.
EDIT: Bei Deinem Tremec 3550 zähle ich nur 5 Gänge. Gibt es das als 6-Gang?
Muncie wird ab Ende des Jahres ein 5-Gang vertreiben, welches die exakten Ausmaße des 4-Gang hat. Der fünfte soll 0.86 Endübersetzung haben. Endlich ein angenehmes Fahren in der C2/3 auch für Originalheimer.
Hallo Franks,
ich bin mit dem Getriebe auch "noch nicht durch" ...
Fa. Keisler bietet für die C3 2 Tremec 5 Gang Kits an:
475 HP Kit: $ 2899
650 HP Kit: $ 3399
und ein 6 Gang 650 HP Kit von $ 3999 bis $ 4999
Schaut mal hier: https://www.keislerauto.com/gm/corvette.html
Ein Vergleich zwischen Richmond und Tremec ist hier ganz schön beschrieben: https://www.5speedtransmissions.com/5sp_comparison.html
ewi
Tja, nächsten Januar gibts wieder einen Container ab Florida - z.B. solche dicken Brocken können da mitschwimmen...... OK!
Gruss,
  Hartes Knacken von der Hinterachse - Posi-trac Differential Probleme? Sebastian_C3_69 9 1.355 18.07.2025, 19:22
Letzter Beitrag: Sebastian_C3_69
  C3 Geräusch an der Hinterachse nach Differential Öl wechsel Tom79 19 2.342 12.07.2025, 18:30
Letzter Beitrag: C3-Fritz
  Kreuzgelenke Hinterachse - Grössenunterschied Warrior90 0 992 11.03.2025, 18:54
Letzter Beitrag: Warrior90
Photo Radlager Hinterachse C2 u. C3: erneuern, vermessen, einstellen,fetten Corv76 33 68.869 09.12.2024, 20:48
Letzter Beitrag: corvette
  C3 hinterachse Bolzen Tieferlegung Thor97 0 1.246 07.06.2024, 22:53
Letzter Beitrag: Thor97
