motorleuchte
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
Das ist der einzige wichtige Code, da immer noch "C", wie current!
Also immer noch aktiv!
Friedel
[Bild: CCHHBanner2.jpg]
CODES auslesen und löschen:
C5 Corvette DIC Codes
Turn the key to the ON position, but don't start the engine. Clear any present messages
by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL
button 4 times. This will get you into the CODES section of the DIC. The computer will
automatically display all the codes your car has created. It will cycle through each code
every 3 seconds. Any code that ends in H is a history code (something that has occured
in the past) but is fine now. Once the computer has finished going through all of it's
codes, press RESET to enter Manual Configuration mode. It should start with a module
and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it
displays "NO CODES". Press OPTIONS to go to the next module. Repeat the steps in this
paragraph until you have reset the codes in all the computer modules. NOTE !! Only
reset the codes IF you want to - it is NOT necessary to do this.
CODE LIST
Das sollte man immer im Mittelfach haben.
Friedel
  Motorleuchte Gladiator 1 1.805 17.06.2014, 11:47
Letzter Beitrag: Gladiator
