Modell 2009 Fernbedienung einbuchen
Hallo, eine Frage zur Europa-Version BJ 2009.
Bei mir hatte eine Fernbedienung gefehlt, die "FOB 1", ich habe heute die fehlende mit der Post bekommen.
Meine Frage, kann ich nach der hier beschriebenen Anleitung die Fernbedienung anlernen oder
kann ich mir die Mühe sparen.
Sonst muss ich zum Händler und extra dafür frei nehmen.
Wichtig Europamodell !!!
Hier der Link: https://www.corvetteforum.de/attachment....37636&sid=
Oder diese Gebrauchsanweisung?
Zitat:
The number on the fob only signifies the order that the fobs were programmed at the factory. All fobs are electrically identical. The order in which you program the fobs to the car determines whether the fob is a #1, #2,#3 or #4.
If the car is working correctly, the fobs can be programmed in a short time without any help from any machines at the dealer. As far as the other statement that fobs must be alternated or they will be forgotten: I was intrigued by this thought, so I just took out my fob #2, which has been sitting in a drawer for almost exactly a year and has never been used with the car, except to test it a year ago. I went out to the car and it opened the car and started it with a surprising lack of excitement. This kind of statement, made up somewhere by a mechanic or someone that he got it from, is just ridiculous on its face, and is the kind of thing that this forum can go a long way towards discrediting, so that it doesn't turn into an 'urban legend' with no basis in fact.
I have programmed dozens of fobs to many C6's and so have written up my own, simplified instruction set for both the short and the long procedure:
C6 Fob, Simple programming instructions….use these when you have a working fob and just want to add another to the system.
1. Car off
2. Trunk open
3. Glove box open
4. Put working fob on console next to shifter (the one you are currently using to drive the car) IMPORTANT. Also make sure no cellphones are in the car.
5. Put key in trunk keyhole and turn key five times in less than 5 seconds.
6. DIC will now beep and light up and say “Ready for fob 3”.
7. Put new unprogrammed fob in slot by glovebox with buttons facing right (passenger) side.
8. Wait and watch DIC. When it says “Ready for fob 4” it is done. Up to four Fobs may be programmed to the car total.
9. When all Fobs are programmed, push OFF/ACC (bottom half of start button) to turn off DIC.
10. Test all four buttons on fob and then take away all other fobs and check car starting with new fob(s).
C6 Fob Programming, long version to erase car memory and reprogram all Fobs. Any lost Fobs that are not reprogrammed with this procedure will no longer work on the car. Lost Fobs that are later found may be added to the car with the short programming procedure. This procedure requires three consecutive ten minute waiting periods, so plan on spending about a half hour to do this, during which the car may not be moved. Remember that the number printed on the Fob only indicates the way it was first programmed at the factory. All Fobs are identical. The order in which they are placed in the glovebox slot determines what number the Fob is.
1. Car off
2. Trunk open
3. Glove box open
4. Make sure NO Fobs are anywhere near the car. IMPORTANT.
6. DIC will now beep and light up and say “Off/Acc to learn” If you decide at this point NOT to do the programming now, push the TOP half of the Start button and the car will return to normal. To continue with programming:
7. Push bottom half of the Start button. DIC will say to wait 10 minutes and will start counting down the minutes. You may close the trunk and car door while waiting for the ten minute countdowns.
8. After the first 10 minute countdown, DIC will again say “Off/Acc to learn”. Push bottom half of Start button again. DIC will again start counting down the ten minutes.
9. After the second 10 minute countdown, DIC will again say “Off/Acc to learn”. Push bottom half of Start button again. DIC will again start counting down the ten minutes.
10. After this third ten minute period is over, DIC will say “Ready for Fob #1” Regardless of the number on the Fob, the FIRST Fob that is put in the glovebox slot will be recognized as Fob #1. Put the first Fob in the glovebox slot with the buttons facing to the right (passenger) side.
11. After 3 or four seconds the DIC will beep and say “Ready for Fob #2”. Put the second Fob in the slot. The car will take a maximum of four fobs. When you have no more Fobs to program, push the bottom half of the Start button to end the programming session.
12. Test all buttons on the fobs to make sure they work, then take all fobs away from the car and, one by one, try using each to start the car.
Good Luck!
Schöne Grüsse aus dem Weserbergland
Theo Erwin
"Loud Pipes Save Lives"
Hallo Theo,
die Prozedur habe ich schon an meiner US-Vette probiert, ohne Erfolg. Bei der EU-Vette soll es damit garnicht gehen, habe ich im Forum schon gelesen. Du kannst es mal probieren, aber es ist vergebene Liebesmühe, denke ich.
Gruss....Ralf
Auf Seite 248 steht...
Zitat:Änderungen an diesem System dürfen allein von einer Vertragswerkstatt vorgenommen werden; andernfalls könnte die Gebrauchsbefugnis für dieses System nichtig werden.
Nr. 30 Großes Grinsen
haben Sie etwa eine deutsche Anleitung, oder ist das nur übersetzt.
Wenn dt. Anleitung, wie kommt man an die
gruss
ein Technikfreak
Nein Kopfschütteln, haben sie nicht, aber einen Link Yeeah!
KLICK MICH
KLICK MICH
super Danke nun muss ich mich nicht mehr mit Englisch rumquälen
ein Technikfreak
ich war beim Händler, die neue Fernbedienung ist eingebucht, als Nr.3, es geht
alles bis auf die Optionen, also kann auch die Sprache nicht auf Deutsch gestellt werden.
Aber egal!
Hauptsache Sie geht.
Theo Erwin
Zitat:es geht alles bis auf die Optionen
Und warum gehen die nicht?
Hallo JR,
der Mechaniker meint:
Wenn Schlüssel 1+2 komplett gelöscht und dann neu programmiert werden, kann es sein, dass
nichts mehr geht und im schlimmsten Fall das Armaturenbrett zerlegt werden muss.
Daher wurde der Schlüssel auf Nr. 3 eingebucht, es geht nun auch alles, nur halt in Englisch, nur
der Modus Optionen wo auch die Ländereinstellungen sind geht nicht.
Ich lasse das jetzt so, kann ich mit leben.
Theo Erwin
Zitat:Original von Harleytheo
Hallo JR,
Hallo Theo Erwin
Ich habe letzte Woche ebenfalls einen Schlüssel bei meinem EU-Modell auswechseln lassen müssen. Nun habe ich dasselbe Problem, die Optionen bei der neuen FOB funktionieren nicht mehr. Drückt man die Optionstaste, erscheint die Meldung "keine Optionen verfügbar" in englisch. Beim Starten erscheint keine Anzeige mehr und die Standardanzeigen erscheinen alle in englisch. Ich kann deshalb auch nicht sagen, ob es neu Schlüssel 2 oder 3 ist.
Freundliche Grüsse
Reto
  Garagentor Fernbedienung Sonnenblende US C6 CorMon404 6 2.656 05.02.2024, 12:57
Letzter Beitrag: schupppe
  Batteriewechsel Fernbedienung US Modell Tim11 8 3.554 03.11.2023, 10:40
Letzter Beitrag: Bert_33
  Standlicht C6 EU-Modell Fordy 5 3.767 09.05.2022, 23:34
Letzter Beitrag: Fordy
  Europa Modell erkennbar ? corvette-mike 5 4.175 30.11.2021, 14:33
  Neue FB Kodierung C6 2005 EU Modell Seko_C6 4 4.410 09.09.2020, 15:23
Letzter Beitrag: Seko_C6
