Membran Lumbar-Pumpe
Smile
Moin Moin,
ich habe gerade Axel's Pumpe aus dem Fahrersitz geschraubt um nachzusehen was defekt ist.
Fazit: Die Membran ist durch.
Frage: Gibt es da ein Ersatzteil für? Oder was kann man da sonst reinschrauben?
e.
Hallo Eike,
das Ding kannst Du mit einem Gummihandschuh reparieren.
Anleitung (leider neudeutsch):
A very common problem with the C4 sport seat is the failure of the pump that inflates the lumbar bladders internal to the back of the seat. The most prevalent failure is not the pump assembly, but simply the diaphragm within the pump sub-assembly. To gain access to the pump, look under the front of the seat and there will be a wire clip that holds the bottom seat cushion in place. Push this clip down and back and then lift the bottom cushion and position it so you can see underneath. Next, follow the air tubes from the lumbar support switch and bleed console (right side bolster) to the pump. Remove the three small bolts that hold the pump to the seat frame. Note, it is easier to remove if you use the seat adjustment on the console to lift the front of the seat to get your hand in. These screws must be removed from the bottom as the nuts visible from the top are set into a hex shaped depression in the plastic. Once the pump is free, disconnect the two power connections (disconnect the battery first) and then disconnect the three tubes from the pump. The pump should now be free to remove from the car and take into a work area where you won't lose all the small parts that you will have during disassembly.
To access the diaphragm, remove the two small Phillips head screws at the pump end of the motor and remove the access plate. Make note of the orientation of the three tube nipples in relation to the pump housing and then slide the pump sub-assembly out of the housing while carefully making sure that the plunger slides off the crankshaft of the motor at the same time. Once the pump sub-assembly is free of the housing, you will quickly find out if the diaphragm is torn as is usually the problem with these pumps. Remove the four Phillips screws that hold the pump sub-assembly halves together and then remove the diaphragm. This is a good time to take the motor back out to the car without the pump sub-assembly, plug in the two connectors, re-connect the battery and ensure that the motor runs. If not, then you will need to replace the entire pump. Disconnect the battery again prior to removal.
There are two ways to fix the diaphragm, by making a replacement using household items and a more expensive way using replacement parts. GM would like you to buy the entire pump assembly at more then $130 rather then fix the diaphragm. However, you can buy the pump subassembly from Jasco Products (original supplier to GM) in Sun Valley, CA for around $33. The second more creative fix, it to use a dish washing glove to make a new diaphragm (make sure you wife isn't looking when you take the glove). Trace the outside diameter of the original diaphragm onto the flat portion of the glove and then cut out the circle (approximately a 19/32 inch radius). Next, remove the screw and the sealing washer just under the screw head from the plunger. You will find the center of the old diaphragm in the recess of the plunger, leave this in place to fill the recess. Next, punch a hole in the center of your new diaphragm with a pin and then push the screw with the sealing washer through the diaphragm and then attach to the plunger. The final assembly order should be: screw, sealing washer, new diaphragm, old diaphragm center piece, sealing washer, plunger. Finally, put the diaphragm into the pump sub-assembly halves. To ensure the correct alignment of the plunger, put a drill bit through the hole in the plunger where it slides onto the crankshaft. The hole should line up with the previously noted position of the tube nipples, i.e., the drill bit should be perpendicular to the tube nipples. (Failure to get this hole in the correct orientation will cause the pump to bind.) Now screw the two halves back together with the four screws previously removed. Put a small dab of grease on the crankshaft (the grease used should be compatible with rubber) and then slide the pump sub-assembly back into the housing while making sure that the plunger slides onto the pin of the crankshaft. Once again, take the pump out to the car and plug in the connectors to make sure the pump operates correctly. Re-install the cover plate and then re-install the pump into the seat by reversing the removal operation.
Jau, besten Dank - probieren wir mal. Prost! OK! Respekt
Poste dann bitte mal das Ergebnis.
Mein Fahrersitz hat glaube ich da auch ein Problem...
PS: Der Gummihandschuh ist dann aber nicht mehr originooool! Feixen
Ich bin mal sämtliche Kataloge durchgegangen und bin bei CorvetteCentral als günstigsten
Anbieter hängengeblieben.
Die Membrane gibt es nicht als Einzelteil.
Die neue Pumpe kostet 79,- $ und als Repair-Kit immerhin noch 39,- $.
Zitat:Repair-Kit immerhin noch 39,- $
Das ist ja ein unverschämter Preis für ein Verhüterli... Kopfschütteln
Mal sehen, ob das mit dem Handschuh klappt.
Nach den Beschreibungen sollte es das tun - allerdings soll man die etwas besseren und dickeren Handschuhe nehmen, diese hätten in etwa die Stärke der Originalmembran.
Eigentlich wäre das doch auch ein Fall für Sikaflex zum abdichten???
Gruss,
An SikaFlex hatte ich auch schon gedacht.
Wenn das Zeug trocken und ausgehärtet ist,gleicht das einer Schweißnaht und reißt
eher nebendran wieder ab. Aber niemals an der Klebestelle.
Edit! Die schadhafte Stelle kann man mit Nadel und Faden fixieren,
dann das SikaFlex auftragen. 12 Stunden bei 21° aushärten lassen.
So sollte es gehen.
Ich dachte eigentlich nicht an das tapfere Schneiderlein mit den 7 auf einen Streich sondern an das Abdichten der Membran zur Pumpe..... Großes Grinsen
Gruss,
Ja, also ich weiß nicht so recht wie ich es schreiben soll, aber das mit dem Gummihandschuh geht schon in die Richtung genial - funktioniert jedenfalls.
Ist nicht ganz so gut wie original, aber wen interessiert dieser winziege Unterschied schon ?
e.
  Air Pumpe windhund 1 5.090 11.09.2020, 15:48
Letzter Beitrag: herbertram
  Suche C4 Smog Pumpe VetteMino 3 9.722 15.02.2019, 11:40
Letzter Beitrag: Thomas ZR-1
Brick Sitzverstellung Beifahrer und Lumbar funktionieren nicht corvettex 3 3.020 13.05.2014, 09:06
Letzter Beitrag: corvettex
  Pumpe vom Sitz Peter Rumann 6 5.112 09.05.2014, 08:39
  Pumpe von Automatikgetriebe neo 3 3.106 22.06.2008, 22:51
Letzter Beitrag: CCRP
