Neues billiges KEISLER 5 Gang overdrive
KEISLER hat wohl ein neues verdammt günstiges 5 Gang Overdrive Getriebe im Angebot.
Obs in die Vette passt, müsste man mal nachfragen.
Der Preis ist heiss.
Dear Fellow Enthusiasts,
We just got back from SEMA in Las Vegas where we debuted some great new products and met a number of you that are professional shops looking to grow your business with Keisler.
Please take a few minutes to check out these exciting new products that continue the trend of Innovation and growth that started the company 17 years ago:
Keisler T45 RS 5 Speed
Keisler Launches the T45 RS - a Low Cost, High Quality Performance 5 Speed Manual Transmission for Just $1295 for classic cars, muscle cars, street rods and late model Mustang is based on an in-house custom built Borg Warner performance manual transmission bringing you everything you want - overdrive, complete custom fit, affordable price.
Nearly $1000 less than a comparable PerfectFit TKO Kit - Unbeatable Value !. The T-45 RS includes all new upgraded carbon fiber synchronizers, bearings, seals and gears (as required), new high strength alloy front casting, and a new super duty input shaft featuring oversize 1-1/8 inch x 26 spline (requires clutch disk change). An all new billet machined PRO shifter with internal spring biasing provides positive and crisp shifts. Powder coating optional. 12 month warranty.
64_-_73_t45rs_1_mustang_transmission_photo_web_sized
Key Selling Points:
- Unbeatable value to install a modern 5-speed overdrive into a muscle car, street rod or truck.
- Up to 33% RPM drop & more than 35% fuel efficiency improvement on highway
- Bolts directly to factory aluminum and SFI racing bell housings
- Excellent for small block and mild big block applications
- Includes $200 pro-shifter as standard equipment
- Superior shift quality through single rail design; comparable to T56
Retail: bare unit $995 - $1495
Complete kits -$1995
Rating: 400 HP / 400 FT-LB
Ratios: 3.37, 1.99, 1.33, 1.0, 0.67
Wenn es passen würde wäre das eine interessante Sache.
Dann noch über eine größere Bestellung ein paar $ sparen - das wäre es doch.
Ist sicher interessant bis 400PS!
Bis " Rating: 400 HP / 400 FT-LB " !
Was bedeutet denn Overdrive hierbei ? Der Fünfte mit mit 0.67 Ratio ?
Für den Kurs ist das Getriebe sehr interessant OK!
Hallo-gruen , .................
Falls jemand Interesse hat, ich schlachte im Dezember meinen bisherigen Trans Am GTA. Dort steckt auch ein tadellos arbeitendes Borg-Warner T5 WorldClass drin, verrichtete bisher einwandfrei seinen Dienst am 5.0 TPI Motor Zwinkern
2012 Cadillac CTS-V Sedan, M6
Frank.
Hierzu bietet sich doch ,die Alljährliche Container Aktion,von Frank Hohl an.
Porter.
Ganz genau Porter,der fünfte Gang würde deine Motordrehzahl erheblich senken.
Dazu gibt es auf der Seite von Keisler einen Rechner,der einem ,bei eingegebener Reifengröße und Achsübersetzung die Drehzahl ausrechnet.
https://www.keislerauto.com/index.php?/s...yzers.html
M.f.g. Uwe
Uwe
Danke Uwe, war nur etwas begriffs-stutzig Großes Grinsen
Nur für unsere Torque-Twister ist das leider unterdimensioniert Heulen
Burnout , .................
Hi
Für die meisten SB und viele BB hier würde es voll ausreichen.
Die
Zitat:Torque-Twister
müssen eben auf das viel teurere TKO 5 Gang oder gar verstärkte T56 ( 650 Ft/LBS ) zurückgreifen.
  Muncie 4-Gang - Ölverlust an Eingangswelle eleminieren Carioca83 0 353 18.08.2025, 14:31
Letzter Beitrag: Carioca83
  Corvette C8 - neues Video marlboroman 35 30.725 19.02.2018, 23:40
Letzter Beitrag: thocar
  Camaro ZL1 / 10-Gang - Nordschleife 7:29.60 P.A.J. 6 6.062 23.06.2017, 14:48
Letzter Beitrag: wolfgang s
  4-Gang-Schaltgetriebe Saginaw macht Geräusche Camaro WS6 4 4.920 07.06.2017, 09:11
Letzter Beitrag: Camaro WS6
  Billiges umweltfreundliches Benzin entwickelt corvettesepp 9 4.674 08.02.2014, 17:34
Letzter Beitrag: V8-Mike
