MP3 C6 ab 2007 Anleitung CD Brennen
Shocked
Hi
Hier noch mal die Anleitung zum Brennen mit Nero 7
Hi @ All
es Funst !!!!!!!!
die Einstellungen bei Nero 7 Burning Rom müssen so aussehen:
CD-Rom ISO
# Datenmodus: Mode 1
# Dateisystem: ISO 9660
# Dateinamenlänge: Max. von 31 Zeichen (Level 2)
# Zeichensatz: ISO 9660 Standard
# Pfad tiefe : Haken setzen
#mehr als 255 Zeichen : Haken setzen
Hier die Antwort von GM :
This PI was superseded to update MP3 functionality. Please discard PIC4471.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may comment that their Navigation radio will not play MP3's. Typically this concern will occur when the customer creates several folders and burns the disc as a DATA DISC. Data disc's can be made in two different formats. These formats are refered to as Mode 1 or Mode 2/XA. Format Mode 1 is selectable only through the software program that the customer used to burn the CD. Some software may not allow this Mode to be selected. It has been found that typically, if the software used to burn the CD does not allow the user to select Mode 1, then the software is likely burning the CD in Mode 2/XA.
Important: Mode 2/XA is NOT supported by the Navigation Radio.
If you are unable to select Mode 1 prior to burning the disc, you should contact the software manufacturer for assistance. Many software programs that support selection of Mode 1 also allow you to view the Disc Properties which may also indicate what Mode the customer's CD was burned in. The customer may have to purchase additional software at their own expense in order to burn CDs that will be compatible with the Navigation Radio and comply with the required criteria as covered in the Owner's Manual.
Recommendation/Instructions:
This is normal operation of the Navigation Radio. Do not replace the radio for this concern. Additional information that referenced MP3 formats can be found in the customer's owners manual or Navigation Radio Supplement.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
habe es mit Oli zusammen ausprobiert und geht Einwandfrei
21.02.2008
Hi
habe Heute noch drei Vettten bei Dürkop Kassel ausprobiert 2007 & 2008 Modell !!!
geht 100% 135 Titel 700 Mb Phillips CD-R
viele Grüße Peter
rot muß die Vette sein !!!
[Bild: attachment.php?attachmentid=16046&sid=]
Hallo Peter ist im Endeffekt nichts anders als wir letztes Jahr im Mai schon festgestellt haben. Kopfschütteln
Hat GM eventuell hier gelesen Frage
Das war das Fazit vom Mai 2007:
Zitat:Werkzeuge:
Brennprogramm: Nero Burning ROM, download hier
Programm zum Anpassen der Tags: Mp3tag, download hier
Programm zum Anpassen der Lautstärke: MP3Gain, download hier
Programm zum kombinieren von MP3s: MP3 Splitter & Joiner, download hier
Programm zur Formatumwandlung: GXTranscoder, download hier
Der letzte Schritt hier mal zuerst - Das Brennen
Ich habe ein paar verschiedene Brennprogramme ausprobiert aber das gute alte Nero klappt am besten. Ihr erzeugt eine DATEN CD-ROM ISO (keine Audio CD!) und zieht Eure MP3 Folder in den Brennbereich. Der Trick ist jetzt die Settings richtig zu haben. Dazu geht Ihr auf "Datei" - "Zusammenstellungseigenschaften" oder drückt einfach "F7". Dort seht Ihr ein Reiterfeld mit dem Titel "Multisession". Klickt hier auf "kein Multisession", das hat bei mir die besten Ergebnisse erzielt. Im Reiter "Brennen"wählt Ihr unter "Schreibmethode" dann "Disc-at-once" aus. Ebenfalls kein Muss, klappt aber am besten.
Das entscheidende ist der Reiter "ISO". Dort wählt Ihr folgendes aus:
* Datenmodus: Mode 1
* Dateisystem: ISO 9660
* Dateinamenlänge: Max. von 31 Zeichen (Level 2)
* Zeichensatz: ASCII
* Beschränkungen: anklicken der ersten und zweiten Box.
Sie hier: Mai 2007 So funktioniert es mit MP3
Bis bald
Mosty
http://www.c6cabrio.de[Bild: a050.gif][Bild: levelover2.gif][Bild: CTCK.JPG]
Hi mosty
* Zeichensatz: ASCII ist der Fehler !!!!!
#Dateisystem: ISO 9660 + Joliet ist der Fehler !!!!!
[B# Zeichensatz: ISO 9660 Standard , so ist es richtig !!!!!B]
# Dateisystem: ISO 9660 , so ist es richtig !!!
ich finde einen alten Link anzugeben wo sich alle beschwert haben das es nicht geht , nicht richtig Kopfschütteln
viele Grüße Peter
Hi
hier nochmal die Antwort von Heinz & Olli
Hallo Peter (Bugs)
Habe Deine Anweisungen befolgt und die erste CD erstellt und überprüft ---
sensationell ---- einfach Spitze, klappt super
erst einmal 100 Titel auf eine CD gebrannt und ausprobiert alles klappt
Titelwahl --- nächster Titel --- einfach toll --- ich freue mich.
Du hast mindestens ein verdient.
Ich danke Dir
Viele Grüße Heinz
Hallo, ich habe zusammen mit Peter die Ausprobe gemacht und bei mir, wie auch bei Ihm läuft alles bestens. Bitte achtet darauf das der CD Player nicht zufällig auf der Zufallswiedergabefunktion steht, dann spielt er selbstverständlich die CD-R durcheinander.
Viel Grüße
Olli
von mir
Hi
viele Grüße Peter
Hi
habe Heute noch mal 3 CD-R 700 Mb verschiedener Hersteller mit 133 Titeln gebrannt !
Funzen alle 3 einwandfrei Yeeah! Yeeah!
viele Grüße Peter
Statusbericht:
Heute CD mit 179 Titeln Yeeah! gebrannt Zwinkern
klappt immer noch sich vor Lachen auf dem Boden wälzen
Bin begeistert Yeeah!
Gruß Heinz Prost!
Zitat:Original von C53
Statusbericht:
Gruß Heinz Prost!
Hallo Heinz,
Glückwunsch, ich sehe schon Du bist der absolute Profi. Prost!
Siggi
Schleimer sich vor Lachen auf dem Boden wälzen sich vor Lachen auf dem Boden wälzen sich vor Lachen auf dem Boden wälzen
Gruß Heinz Zwinkern
Gruß Heinz Zwinkern
@Heinz,
jetzt will ich Dich mal loben, und nun is es auch wieder nich recht. Feixen Feixen
Siggi
[quote]Original von mosty
Doch Mosty, es ist etwas anderes, es werden ganz andere Parameter gesetzt. Es geht bei den Einstellungen die wir gepostet haben ohne Probleme. Schade ist allerdings das Du auf eine Seite verlinkst, die wir schon hatten und bei der es aber nicht funktioniert hat.
GANZ WICHTIG IST DIE PLAYEREINSTELLUNG DARF NICHT AUF ZUFALL STEHEN; SONST SPRINGT DIE CD-R LOGISCHERWEISE ZU TITELN DURCHEINANDER.
Mit freundlichen Grüßen
Olli
Hubraum ist durch nichts zu ersetzen, außer durch mehr Hubraum
  Innenspiegel C6 Convertible Bj 2007 Howie 2 1.498 25.07.2023, 09:40
Letzter Beitrag: Howie
  Gurtwarner abschalten - C6 Cabrio 2007 canus 42 23.060 12.07.2019, 09:41
Brick Türverkleidung abbauen - Anleitung? Janvandam 7 13.128 02.06.2019, 15:29
Letzter Beitrag: Janvandam
Question Preisermittlung Corvette C6 Bj. 05/2007 Euromodell Patrick C6 17 14.874 01.03.2019, 20:19
Letzter Beitrag: Netzpirat9
  Bluetooth in C6 Cabro US 2007 canus 2 3.470 15.06.2018, 23:27
Letzter Beitrag: galaxy7
