lost power
Hi ZR1 gurus , I have question for you.....
I just came home from a long trip....I made over 1000km and on the last 300 I lost full
engine power and engine service soon light come on my display . I clik key to normal and
car run as usually without engine service light. I stop the engine and chek air pump - it is run ok
with no air leaking.....where could be problem ??? second fuel pump , secondary injectors or
what...I also chek fuses , they are ok... Hilfe!!
thanks for any answers,Jano
You have to check the correct vacuum from the Air pump.
secondary injection ports rusted?
Hallo-gruen
Kai
I done , there is no vacum leak and air pimp runing well ,
how can I check both fuel pumps ???
I find one -secondary bad fuel pump , problem is solved !
jano
  Power-Chip für ZR-1 becktom 4 6.952 15.05.2008, 23:25
Letzter Beitrag: becktom
