Klimaanlage Fehlercodes für 89er
Hat jemand eine Liste mit den entsprechenden Codes?
Die Anlagen >89 sind nicht kompatibel! Allein das Auslesen läugt schon anders.
Bekomme Code 11. Frage
Gruß aus Aachen,
Ruben
Na ich beantworte meine Frage mal selbst. Ein netter mensch im .com Forum hat mir die Codes gemailt. Vieleicht kann es ja noch jemand gebrauchen.
Hier nocheinmal für alle:
here are twelve diagnostic modes.
Diagnostic mode -8 is the most commonly used mode for
diagnosing the system.
The diagnostic mode is entered while pressing the EXT
TEMP button and then pressing and releasing the AUTO
FAN button. Once the diagnostic mode is enabled the
mode number may be changed by pressing the WARM
button.
The contents of the mode may be displayed by pressing
the COOL button. The mode number displayed is proceded
by a minus sign.
Mode #01 -Program Number
Mode #02 -In Vehicle Thermistor
Mode #03 -Ambient Correction
Mode #04 -Blower Number
Mode #05 -Outside Temp. Thermistor
Mode #06 -Feedback Pot position
Mode #07 -Calculated door position
Mode #08 -System Faults *******
Mode #09 -Ratiometric Feedback Position
Mode #10 -Full Hot Position
Mode #11 -Full Code Position
Mode #12 -Software Version Number
Diagnosis for this system is based on diagnostic codes
stored in the Heater and A/C Control Assembly. When a
code has been stored the EXT TEMP indicator will
flash.
To enter the Diagnostic Mode and read the code, press
and hold the EXT TEMP button while pressing and
releasing the AUTO button. A mode number will appear
in the display.
The diagnostic mode for system faults is Mode -08.
Advance the display to -08 by repeatedly pressing the
WARM button. The diagnostic code may now be displayed
by pressing the COOL button.
If a single code is stored, it will be listed in the
Symptoms Table. If more than one code is stored, the
number will represent the sum of the codes.
For instance code 11 is (01+02+08)=11
Air Mid Valve Actuator Feedback Open
Outside Temp. Sensor Open
In car Temp. Sensor Open
Code 00 No Faults
Code 01 Air Mix Valve Actuator Feedback Open
Code 02 Outside Temperature Sensor Open
Code 04 Outside Temperature Sensor Shorted
Code 08 In Car Temperature Sensor Open
Code 16 In Car Temperature Sensor Shorted
Gruß aus Aachen,
Ruben
Question Controller für Klimaanlage/Klimabedienteil Cory2016 7 1.101 07.05.2025, 14:06
Letzter Beitrag: Cory2016
  C4 Ledersitze neu beziehen oder fertig kaufen , 89er Cabrio Der_Daniel 3 1.726 18.02.2025, 20:04
Letzter Beitrag: Vettepotsdam
  91er SYS blinkt / Fehlercodes lassen sich nicht anzeigen Roma 25 9.254 04.08.2023, 10:59
Letzter Beitrag: chevyunger
  Kosten Klimaanlage umrüsten / Kompressor erneuern T_Vette3 12 4.659 14.07.2023, 15:38
Letzter Beitrag: usc-driver
  Klimaanlage uwek 8 4.203 18.01.2023, 13:52
Letzter Beitrag: uwek
