Themen: 22
Baureihe: C6 Coupe
Baujahr,Farbe: 2008 weiß
Baureihe (2): silber 2006
Baujahr,Farbe (2): SLK 55 amg
Baureihe (3) : silber 2007
Baujahr,Farbe (3) : Z4 Coupe
Kennt einer von euch diesen Fehler C0561?
Grüße Thomas
hab es Dir mal aus dem C6 Service Manual kopiert......
hilft Dir das?
DTC C0561
Circuit Description
The electronic brake control module (EBCM) disables the traction control when other electronic control modules set DTCs for components that effect the operation of the traction control system (TCS).
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC C0561 System Disabled Information Stored
This vehicle has DTCs which include DTC Symptoms. For more information on DTC Symptoms, refer to DTC Symptom Description in Vehicle DTC Information.
DTC Symptom
DTC Symptom Descriptor
71
Invalid Serial Data Received
Conditions for Running the DTC
The ignition is ON.
Ignition voltage is greater than 8 volts.
Conditions for Setting the DTC
The powertrain control module (PCM) or body control module (BCM) diagnoses a condition preventing the engine control portion of the traction control function and sends a serial data message to the EBCM indicating that torque reduction is not allowed. The PCM or BCM will typically set a DTC and the EBCM will set this DTC.
Action Taken When the DTC Sets
The EBCM disables the TCS until the DTC becomes a history DTC.
The Traction Off indicator turns ON.
The antilock brake system (ABS) remains functional.
Conditions for Clearing the DTC
The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
This DTC is for information only. As an aid to the technician, this DTC indicates that there are no problems in the ABS/TCS system.
Themen: 22
Baureihe: C6 Coupe
hilft Dir das?
DTC C0561
Circuit Description
DTC Descriptor
DTC Symptom
71
The ignition is ON.
Diagnostic Aids
Danke Dir
Heißt das, wenn ich die aktiven Fahrhilfen vollständig wegschalte, dass das System das aufzeichnet. Und mir dokumentiert das ASR usw. nicht funktioniert.
Demnach ist C0561 kein Funktionsfehler?
Grüße Thomas
Themen: 41
Lux
Baureihe:
Honda S2000
Baujahr,Farbe:
New Imola Pearl
Das heisst, dass deine Traktionskontrolle nicht funktionniert, weil ein anderes Modul welches zur Funktion benoetigt wird nicth arbeitet wie es soll (das ABS System zB)
Es müsste demnach noch ein weiterer Fehler gespeichert sein!
Themen: 22
Baureihe: C6 Coupe
Gut das ich noch nichts gelöscht habe. C0281 ist auch noch vorhanden.
Dynamic Rear Proportioning.
Werde als erstes die Kabelverbindungen checken, wenn o.K. nochmal fahren und checken.
C0281 Stop Lamp Circuit.
Das habe ich auch noch gefunden. Funktioniert aber.
Hat sonst noch einer einen Vorschlag?
Grüße Thomas
