S 6-40
or http://www.zfdoc.com
kfz-holzer.de
Thank guys
Im buying from Kurt and Bill many years , but allways I must buy kits....If I need first bearing
I must buy all for 300$ etc..now i need 6th synchro they would sell to me kit for 700$
..I HATE THIS WAY OF ECONOMY. huahua
I have many new parts from kits here at home which I will never use.
So this is reason for asking if any chance to get parts from factory ZF GMBH.
regards to all, JANO
The reason why you have to buy kits is that Kurt White and Bill are also buying from ZF USA and they ONLY sell some parts in KITS.
You cant get S6-40 parts out of Germany, except they are imported from USA.
You will get a quote on your requested parts.
TEST TEST TEST
Zitat:Original von jano
Thank guys
I bought a synchro kit and only needed one .
There are only two kind of rings , for the first and second gear ( dual cone ) and for the 3 - 6 gear .
I can sell you one or Two rings .....
Gruß Mario
Thanke you Mario for help,
but I just got mail from Kurt that he will sell sell to me SEPARATLY
two synchro rings (nmb 311 & 415).
Im still looking for used but good 5/6 sliding sleeve and gear 5th.
I have for trade or sell all nedle berings except 1. gear....
so let together make big ZR1 spar parts inventory here on the forum !
jano
Gear 5 no problem.
TEST TEST TEST
Das mußte der Offizielle ZF Ersatzteil Distributor für ZF Corvette Getriebe sein.
https://www.rsgear.com/zf.html
Raimund
[Bild: c4sign.jpg]
Corvette C4
