1989 White C4 Corvette
(26.09.2019, 13:32)Woodstock schrieb:
(26.09.2019, 12:35)C schrieb: But I still want to have an expert to have a look at it.
Where are you and where's the C4 located?
I'm in Austria, close to Villach.. but I have a trailer to put the car on.
Hi
It would be more interesting to know where the car is, in order for an expert to assist you in investigating
the issues .
Rgds Günther
(26.09.2019, 16:01)Wesch schrieb: Hi
the issues .
Rgds  Günther
In Austria - VillachZwink
Small update:
1. tires are very old, need 4 new tires.
My tires are 275/40/ZR17 on sawblade rims, not difficult to find and pretty cheap options.
2. alternator/Lichtmaschine = new but does not charge the battery, I suspect something is wrong with the cables.
Seems to be a problem with fuses/cables.
3. Only 6 cylinders are working
got all 8 cylinders working.
4. Oil leak from the Automatic transmission, the seals need to be replaced.
No update.
5. New brakes
No update.
6. Katalysator needs to be replaced
When looking under the car, I see that two Katalysator are removed (left and right) just 40-50CM after the pipe leaves the engine. The device (I assume also a Katalysator or muffler) is still there. What options do I have?
https://www.reifensuche.com/kaufen/suche...=price:asc
  Verlorener Chip-Schlüssel, C4 Cabrio, 1989 Mike Habel 5 2.300 29.06.2024, 16:22
Letzter Beitrag: Mr.Cortez
  Corvette Werbung Automobil Revue 1989 Glarus 11 5.012 12.05.2021, 16:04
Letzter Beitrag: Glarus
  C4 1989 startet nicht Max 5.7 5 6.779 22.03.2021, 13:01
Letzter Beitrag: Max 5.7
  Handbremsseil Befestigung Bracket 1989 - 1996 V8Lounge 3 4.080 08.12.2020, 17:35
Letzter Beitrag: V8Lounge
  Preis für C4-Lichtmaschine, Version 1989 mit L98 Coolcruiser 10 12.558 11.08.2020, 17:49
Letzter Beitrag: Sadibaer
