03.05.2019, 13:52
Ich kenne es von SCT Handheld für den Mustang.
Schaltdruck + Geschw. zu ändern.
Denke für die Vette gibt´s sowas auch.
z.B
DiabloSport inTune i2 - Handheld Tuner. https://www.zip-corvette.com/blog/corvet...-tuner-c6/
Tuning Paramaters:
Cooling Fan – On/Off Temperatures Rev Limiter
Multiple Fuel Adjustment Points Shift Points – RPM Full Throttle
Multiple Timing Adjustment Points Shift Points – MPH (Up/Down)
Injector Adjustment – Injector Size/LT Fuel Trims Shift Pressure – part Throttle
Rear O2 Sensors - EGR On/Off (Race Use Only) Fuel Table – Adjustment
Torque Modulation On/Off Per Gear Global Spark
MAF Curve – Adjustment Idle – Adjustment
Timing Table – Adjustment Shift Pressure
Torque Management – On/Off Shift Timing
Traction Control – On/Off Speed Limiter
DiabloSport Predator Features:
Will Not Void Factory Warranty Internet Updatable
Diagnostics – Read & Erase Fault Codes Data Monitoring
Large Backlit display Data Logging
Holds Up To Five Custom Tunes Performance Calibrations
30+ Horsepower Gains Free Firmware Updates
z.B
Tuning Paramaters:
Lächle. Du du kannst sie nicht alle Töten.
