Einsames Pferdchen sucht neuen Stall!
Hallo!
Ja, ich weiß: Ein Mustang ist keine Corvette! Aber der hier ist wirklich schön und muß weg...
Wenn Ihr also jemand kennt, der ein solches "Pony" sucht: Zeigt ihm doch mal den hier!
https://www.youtube.com/watch?v=9lbjV0dI0K8
Ist ein 66er mit 302er V8. Über 10.000$ alleine an Teilen in den letzten 2 Jahren investiert, der Motor seit Resto 1500 miles gelaufen. Was genau gemacht worden ist, liste ich einfach mal im Original auf!
Ach ja, der Preis: Er wird so um die 15.000€ liegen. Allerdings ist das OHNE TRANSPORT UND ZOLL!!! Den Transport kann man schließlich von billig bis "exclusiv" erledigen!
Bei Interesse kann man mich gerne kontaktieren!!
Danke für eure Unterstützung!
Gunter
1966 Mustang
Here’s your chance to own a beautiful example of Americas favorite Pony car.
The Mustang started the pony car wars and this Restomod continues to carry the torch for Ford fans. This Silver Stone metallic Mustang is the product of a four year rebuild that unfortunately the builder/owner was unable to keep. This is your chance to own a excellent example of a modified Mustang for a very reasonable price. You can buy this car for way less then you could ever build it yourself.
This project started as a bare shell which was stripped completely and then painted in a bright silver and finished with all new chrome. The interior is a combination of red and black, which sets of nicely against the Silver exterior. The drive train is a new 302 which was rebuilt and only has about 1500 miles since the rebuild. It’s mated to a Ford AOD overdrive automatic transmission. The rear is a custom built bullet proof 8 inch Posi.
This car shows extremely well as it was just recently finished and needs nothing to be an excellent driver or weekend show car.
Exterior;
Silver Stone metallic Base coat/Clear coat finish
New window felts
New front and rear glass weather strip
New door weather strip
New trunk weather strip
New tail lights, gaskets and LED bulbs
New back up lights and wiring
New side view mirrors
New bumpers and guards
New exterior door handles
Fiberglass scooped hood with new hinges and trim
New grill molding
New GT fog light bar
New Tri-bar headlights
New Billet gas cap
302 cid badges
Wheels and Tires
New American Racing Torque Thrust grey center wheels
17x8 size
New Toyo Proxes 4 tires
Front- 225/45zr/17 Rear-235/45zr/17
Interior
New carpet and floor mats
New Door panels and water shields
New glove box compartment
New Headliner
New rear seat cover
High back mustang buckets
New dash bezel and turn signal lever
New Sun Tachometer under dash
New package try
New heater plenum and blower motor
New sill plates
New accelerator pedal and brake pedal
New armrest bases and pads
New kick panels
AM/FM radio
Full seatbelts
Motor , Transmission and Undercarriage
New model Ford 302 Rebuilt approx 1500 miles ago
Rebuilt heads
New water pump
Weiand accelerator intake manifold
Holly electric choke vacuum secondary carb
Stainless fuel lines
Mustang “Cobra” style air cleaner and valve covers
Electronic ignition
Rebuilt radiator and new shroud
Billet overflow canister
Transmission cooler with Braided stainless lines
New master cylinder
Front disc brakes and rear drum brakes
Rebuilt Ford AOD overdrive transmission
New rear leaf spring kit
New gas-a-just shocks
New fuel tank and filler neck
New HPC black coated long tube headers with full 2 ¼ inch exhaust
New turbo muffler
New 8 inch Trac-Loc Posi rear member
Refurbished rear end with new axle bearings.
Hilfe!!
Hab ganz vergessen:
Wenn Ihr jemand aus dem Mustangforum kennt (Wenn es so eins gibt?!), wäre es toll, wenn der das Auto dort posten könnte!
Offensichtlich kenne ich nämlich keinen...
Nochmals: Danke Hallo-gruen!!
Gunter
schade. ich dachte Du wolltest eine Dame aus dem horizontalen Gewerbe verschachern.
versuchs mal in diesem Forum http://www.dr-mustang.com
da haste mehr Chancen
Die behalte ich, die bringen doch Geld rein! Brauch ich beio den Spritpreisen... Bääh!
Aber wenn Du den Mustang nimmst, bekommst Du eine für ´ne Stunde dazu..... Herz
Oder reichen bei dir 10min? Teufel
Gunter
Danke Camaro!
Bin dort schon angemeldet und warte auf Bestätigung!
Gunter
also bitte! Ich bin kein Mann für eine Nacht!
Nach ner Stunde penn ich ein.
Dann bekommst Du ne olle, häßliche! Da ist an Schlafen nicht zu denken Teufelfeuer
Jetzt aber genug... Ist doch ein ordentliches Forum! Engel
  Wer sucht 69er BB? Ralf. P. 25 12.643 21.10.2016, 15:48
Letzter Beitrag: Pragmatiker
  Corvettefan sucht Hilfe für Hochzeit AndyH 31 11.157 31.07.2014, 00:27
Letzter Beitrag: Solstice
  Hingucker, leider mit Pferdchen statt mit Bowtie DarkRider 24 12.389 28.10.2012, 16:30
Letzter Beitrag: DarkRider
  Welche neuen Reifen für C6? kuki15 12 6.318 26.09.2010, 21:16
Letzter Beitrag: C4L98
  Suche neuen ( alten ) Manta. Wesch 8 4.803 31.03.2005, 13:07
