Sicherung....Auspuffklappen
Also ein Soundfile hab ich nicht - wozu auch Feixen
aber so könnte man es auch optisch und elektrisch schick installieren: Yeeah!
[Bild: 65864970_9e67e45ed5_o.jpg]
Your first decision is whether you want to light a little LED in the switch to differentiate between the two modes. Since there is always power applied to the exhaust cutout fuse, the LED will be on when the switch is in the "quiet cruise" mode. The LED will stay on in this mode even when the car is not running. When the LED is off, the switch is in the "aggressive" mode. This means if you decide to go with the LED, you should always leave the switch in the aggressive mode when you shut the car down or you risk some long term battery drain. This is OK with me because I'll leave it in the "aggressive" mode 95% of the time.
STEP 1: Modify a fuse
The easiest way to make the mods to switch the fuse in/out is to modify a fuse so that you don't have to get to the wiring harness behind the fuse panel.
[Bild: s1.jpg][Bild: s2.jpg]
Always wire a fuse in line!!
Modifying a fuse without having it fall apart was the toughest part of this whole process. Buy a few extra fuses from the auto parts store and try to keep your cool! I used 18 gage wire. Make sure you epoxy or RTV the end of the fuse after you solder the wires to it to give it some structural strength.
Step 2: Remove the mounting panel
There is a little removeable panel in front of the center console glove box. Open the glove box and gentley pry out on the bottom of the panel to pop it out.
[Bild: 65752435_b9977db1cb_o.jpg]
Step 3: Drilling the panel
The switch that I used required that a 15/16" hole be drilled in the panel. Since I only had a 1" spade drill, I used it and compensated for the tendancy of the switch to rotate by applying a little RTV to the back of the switch after it was snapped into the panel. If you use my approach for drilling the hole, make sure you have the panel well clamped or you will tear it apart while drilling. After drilling, smooth the edges of the new hole with sandpaper.
[Bild: 65776384_2f525acf0c_o.jpg]
[Bild: 65780527_685bfee8bd_o.jpg]
Step 4: Install modified fuse/harness and ground lug
The fuse panel is under the passenger footwell. Pull the carpet back and then flap the cover back to access the fuse panel.
If you want to light the LED you will need a ground return and I decided to attach a ground wire lug from the shielded electronic box mount screw next to the fuse panel.
I added an inline fuse that accepts the same mini fuses as the fuse panel to one of the lines running from the modified fuse/harness. I bought the inline fuse holder at Kragens Auto Parts (Cooper Bussman p/n BP/HHM).
Remove the existing fuse that is labeled as "spare" (lower right side of fuse panel) and plug in the modified fuse/harness into the fuse slot. Bend the harness into the right shape so that the modified fuse/harness wants to stay in the fuse socket.
[Bild: 65787476_14302d9f48_o.jpg]
Step 5: Threading harness along tranny tunnel
Pull the carpet and insulation along the passenger tranny tunnel back starting near the fuse panel. Pull the front part of the Emergency Brake boot back (there is a clip that pops out rather easily).
The wire harness is routed from the fuse panel and then in back of the tranny tunnel insulation and up into the Emergency Brake boot area. You can then poke the harness underneath the center console and into the cavity where the panel mounts.
[Bild: 65791309_1abb6d72d7_o.jpg]
Step 6: Attach spade lugs and connect to switch
Mount the switch to the panel (it snaps in place) and apply a little RTV to the back side so that the switch will not rotate.
Attach spade lugs to each wire and plug them into the back of the switch. For the Radio Shack switch the two fuse wires plug into terminals 1 and 2, the ground wire plugs into terminal 3.
[Bild: 65751516_0cc625091c_o.jpg]
Step 6: Pop panel/switch back in place
Snap the panel/switch back in place and enjoy your ability to change your exhaust note at will!
[Bild: 65794930_4ef9e142b8_o.jpg]
Copyright: mehrere threads aus Corvetteforum.com
Gruß Marco
[Bild: bannercag2.jpg]
wie witzig hier doch manche user sind!!!;-)
selbstverständlich meinte ich mit soundfile nicht das klicken des schalters sondern die der aftermarketanlagen!
allzeit unfallfreie Fahrt.
Wie findet Ihr den Vorschlag statt des "normalen" Schalters den Schalter für das F55 zu verbauen? Kann jemand sagen, was ein solcher als Ersatzteil kostet?
[Bild: cska.gif]
welcome to the real world
Finde ich persönlich auch nicht schlecht Denny.
Der Insider weiß zwar das es eine Z06 nicht mit dem F55 Fahrwerk gibt,aber wenn stört's.
Der Schalter ist ein Orginalteil was da IMHO auch prima hinpasst.
Und unauffälliger geht es ja wohl kaum.
Offensichtliche Dinge erwecken weit weniger Mißtrauen als versteckte.
Was er kostet kann ich die leider nicht sagen,aber ein Anruf beim freundlichen dürfte für Klarheit sorgen.
Olly
[Bild: olly_sig.gif]
Hallo Treurentner,
super Antwort auf meine Technik Frage im Technikforum!!
Top Bilder.....so werde ich es machen.....meine Z06 kommt warscheinlich erst im Oktober habe ich gerade erfahren Heulen
Danke nochmal
Michael
da ich technisch absolut untalentiert bin und wahrscheinlich mehr kaputt mache als vorschriftsmässig arbeite eine für mich ganz wichtige frage:
wo kann man solche einen schalter einbauen lassen? preis?
merceeeeeeeee
10361390 Switch electr. susp. F55 kostet 62,55 Euro + MwSt. hier in Deutschland beim Corvette-Händler.
Schöne Grüße
Jens
Zitat:62,55 Euro + MwSt
haarsträubend Aber dann mit Konsole - oder? Engel
[Bild: mijosch-Vette2.gif]
Nr. 30 Großes Grinsen
Ich verstehe immer noch nicht, wieso Ihr die Mittelkonsole mit einem Schalter verschandeln wollt, der da nicht hingehört, statt das Ding unsichtbar in das Ablagefach einzubauen?
Das Zumüllen dieses Faches gilt nicht. Großes Grinsen
HI,
wer ist den schon stolzer Besitzer einer Z06 und kann was dazu sagen ob der Verbrauch mit immer offen Klappen höher ist oder das Dehmoment leidet?
Danke
Michael
  Auspuffklappen gehen nicht zu Jorgos81 18 4.119 17.06.2023, 23:50
Letzter Beitrag: Jorgos81
  Auspuffklappen öffen unbeabsichtigt "Thermo-Zeitventil"? MartinB 21 21.379 23.05.2022, 10:02
Letzter Beitrag: Z06FAN
  Auspuffklappen schließen nicht mehr im heißen Zustand JuergenD 6 9.380 14.07.2019, 19:48
Letzter Beitrag: JuergenD
  Unterdruck für Auspuffklappen Lemmi 15 8.632 20.07.2013, 10:59
Letzter Beitrag: INJA
  Auspuffklappen offen b. niedriger Drehzahl = weniger Durchzug? Dom 14 7.548 23.09.2012, 08:51
Letzter Beitrag: miltiadis
