Jack aus Maine möchte mit seiner 66er C2 Europa bereisen - Tipps? - Druckversion +- Corvetteforum Deutschland (https://www.corvetteforum.de) +-- Forum: Other Vette-Stuff (https://www.corvetteforum.de/forumdisplay.php?fid=8) +--- Forum: Wer weiß was (https://www.corvetteforum.de/forumdisplay.php?fid=10) +--- Thema: Jack aus Maine möchte mit seiner 66er C2 Europa bereisen - Tipps? (/showthread.php?tid=52062) |
- ZEH5didditz - 27.01.2015 Hi Jack. Are you safe of Juno? We heard it is a terrible blizzard runing over NY, Maine and the east coast. I hope you and your family are safe in a warm livingroom.!! The next spring will come... Greets Dieter Update Restoration 2015 - Jack Panzica - 16.03.2015 Gary Ramadei is working on the rear end and I should have it by late April. (Great Rear End Man) lol What started as a stuck plug has changed into a Under body restoration. First the plug would not come out, then the rear end blew, and before you know it project creep. Well I finally got the plug out. I had to remove the welded muffler pipe and header pipe, and after many failed attempts, I used an Irwin stripped bolt remover socket. I heated the plug, I put penetrate on it, I froze it. I had to remove the pipe to be able to hammer on the socket, once on, I could use the long ratchet to remove it. Out it came see photos. The #4 body mount bolt is the one that has me working hard. Got the parts out of car Car ready for additional work Seats have to go Here I go..and it came out See the plug and socket Now fun with # 4 body mount Cleaned up a bit # 4 Body Mount - Jack Panzica - 18.03.2015 Hello to all, We left off with the bolts soaking and all the rubber peeled away on # 4 mount. I went out this afternoon to soak the bolts again and while there I picked a bit at the bushing sleeve and bolt. I decided to give the bolt a little bit of a turn. The result, the bolt came out with the nut . The nut capture cage is not rusted , but the frame mount and and mount reinforcement was rusted, one turn and out it popped. I will let you all give me advice on what to do next. I do not weld ! Mount with rubber still on it Bolt and nut with bushing sleeve Frame mount and nut cage Side view - Porter - 18.03.2015 Hi Jack, know this place of the car too. Don´t want to know how many doesn´t. Good Luck , ........... You need the proper clothes to work on Corvettes - Jack Panzica - 20.03.2015 I went out to the garage , forgot to change my clothes, I was just going to spray a little more penetrate on the bolt holding the reinforcement plate. Well I could not resist putting a ratchet to the bolt. I forgot to take the deck off and just reached in . It took a while to get the right extractor socket on the bolt . 9/16 to big , 1/2 to small. You must be able to hammer the socket on to really get them to work. After 10 minutes, I put my big wrench to it. The one that I am always told not use. Well one click at a time the bolt came out. It took about 20 minutes to get it out, not hard , just one little click because of the tight space. I was them able to remove the rusted mount reinforcement plate . Once removed , I will be able to put a small piece of fiberglass over the hole to hold the nut in the cage. The cage was not rusted . The new reinforcement plate for the # 4 mount will secure the bushing to the body. I will then be able to fabricate a retaining plate for the # 4 frame mount which had a rusted out hole. The mount is good. I will get the plate welded to the mount once I have the car on the road. I was very fortunate to not have a rusted out deck hinge area. All the rust was in the wheel well, except for the retainer bolt. It was only a few inches away from the rusted bushing..... Here are the photos Ratchet in place with a little hammer to hit socket on to bolt View of position of extraction The rusted plate # 4 49 year old bolt with very little rust The old bushing and plate # 4 mount after clean up Close up of nut and cage - rivets still holding it in with very little rust View from below of mount Give the Car back - 6TVette - 20.03.2015 Jack German car manufacturers take cars with high troublefree milages back and refund the owner with a new current Modell. You should contact Bowling Green and ask for their comments to this. Your Vette is a Celebrity on ist own and worth to be exhibited. Including tear and wear and your seat covers. Good Luck Rear End update - Jack Panzica - 23.03.2015 As you all know, this started out as a stuck plug on my tranny. Well the rear end blew and I got a chance to take the rear down to Gary Ramadei, in New Haven CT. He is one of the best re-builders in the country. He did my steering box and now the rear. Here are the photos of Gary at work doing a preliminary inspection of my rear. As you know, it was a mess after blowing up a few months ago. The posi unit would not come out even with the side yokes removed. Gary will use a case spreader later in week to spread the side walls of case so that the bearings and posi can be removed. We tried with a pry bar but could only get it half way out. I will have follow up photos as Gary sends them to me next week. The end result will be a rear that will go from 3:70 back to the original 3:36 that the car was born with. The arrival Proper mounting needed to work on rear Cover is off and that look is not good ! You expect me to fix this ? Oh my ! what do we have here ? Need a big wrench to turn the unit to get at snap rings Got them off after a bit of work Pry Bar did not work Needed a big hammer to get the side yokes to come out, usually they side right out but the case is a little twinkled Side yokes removed Corvette Vagabond's car is 49 years old today! - Jack Panzica - 07.04.2015 I have been fortunate to own the car for 45 of it's 49 years. 46,000 miles on it when I bought it from original owner. Now pushing 300,000 and 4 restorations, visits to 48 states and 15 European countries. Not bad for an old sports car Jack - Porter - 07.04.2015 Not bad for an o.. No: not bad for a real Vette-Owner , ......... - Markstingray - 07.04.2015 Hy Jack, Your car is really great. It was a good experience Driving it as we met last time! |
